Old 04-04-2012, 10:11 AM   #1
2000S
Brakes are not operating properly. I need to step super hard on the brakes to make the car to stop. No pulling. No vibration. The only things i did so far was to remove the wheels and check the ABS sensors, remove the ABS fuse to see if i could isolate the problem and removed the battery cable in an attempt to "reset" everything. No changes.
2000S is offline   Reply With Quote
