Old 04-03-2012, 06:33 PM   #1
crogers106
crogers106's Avatar
Originally Posted by Brad Roberts View Post
Hi! welcome!!
Cool to hear from people from afar!!
Let me ask a question:
Does the window go up/down when you goto open the door? it should go down when you pull on the handle.
I'm betting this is a window regulator issue (common) but it could be the door latch micro switch.
B
Brad, I'm having trouble with my driver side window since buying the car. It drops when I open the door from inside or out but at soon as the door handle is released, it goes right back up so when I shut the door it will hit the top. On the passenger side, the window drop remains in place until the door is closed. I've read several threads and am not sure that this is just an adjustment needed or if it's a microswitch within the door lock mechanism. Any advice appreciated!
crogers106 is offline   Reply With Quote
