Old 03-31-2012, 06:22 PM   #9
ChrisZang
ChrisZang's Avatar
Originally Posted by mikefocke View Post
Most water temp readings on the stock gauge I've heard about are between the 8 and 0 in 180. Both mine were in lots hotter weather with the stock thermostat.
So the 210-220 seems quite high.
Cleaned the radiators recently?
Base or S (with the third radiator)?
Fans under the bumper working (both of them)?
How old is the water pump? Belt?
Cleaned the radiators recently? - Yes, have wire mesh in front
Base or S (with the third radiator)? - "S"
Fans under the bumper working (both of them)? - Yes tested and both working and kicking in
How old is the water pump? Belt? Both changed last summer, when I installed the low temp thermostat
