Old 03-28-2012, 03:45 PM   #1
RandallNeighbour
Check engine light
Well, it sure was a good run. Nearly 2 years of trouble free boxstering!
Got a CE light a couple of days ago.
P0153 Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Below Lower Limit P0154 Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Interruption of Signal
P0341 Camshaft Position Sensor 1 - Signal Implausible, Short to Ground, Short to B+
P1397 Camshaft Position Sensor 2 - Signal Implausible, Short to Ground, Short to B+
P0102 Mass Air Flow Sensor - Below Lower Limit
Borrowed a durametric cable and I'll clean the MAF and swap the O2 sensor to troubleshoot those codes, but the camshaft sensor codes make no sense. They're on opposite sides of the motor. So where do they lead and how do I access it to check the connection?
