Old 03-27-2012, 03:08 PM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by jaykay View Post
Can anyone give me:
-The intake valve opening BTDC in deg and closing ABDC Rennlist ??
-intake valve lift in mm 10.5mm for 2003 3.2 VarioCam + 2000 ??
-intake port size dia in mm 58mm X 30mm @ inlet
-intake valve dia in mom 37.1mm
-actual valve port area in sq mm ??
-bore dia in mm 93mm
-stroke in mm 78mm
-compression ratio 11 to 1
This would be with vario cam actuated on a 3.2L 2000 S
I believe Rennlist has Cam timing specs.
