Old 03-05-2012, 06:38 PM   #5
landrovered
landrovered's Avatar
Remember that the codes are simply data points, just because they exist does not mean that each one means a faulty device.
It is only an event where the data recorded fell outside of the programmed parameters FOR THAT SOFTWARE VERSION. Many codes are simply programmed away by changing the parameters in the next update cycle for the module.
Sometimes they add up to a faulty part, sometimes they are bad software code and sometimes they can tell you more than you really need to know because the data was not designed specifically to be used as a buying tool.
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
landrovered is offline   Reply With Quote
