Old 10-13-2005, 09:57 PM   #5
MNBoxster
Hi,
Generally the softer the compound, the better the grip, the shorter the wear - a trade-off Grip for Wear.
The Tires spec'd for the Boxster are relatively soft compound Tires: 140-220 Treadwear Rating. This means they grip like a Cat, but leave lots of rubber in their wake and so wear quickly. Tires in this range wear between 12k and 20k mi.
But, there is also a Time Component to the Tires' Service Life - NO LONGER THAN 5 YEARS! This is because the tire become harder, losing Grip, and loses it's Heat Management qualities as it ages. This is due to moisture, UV Rays, Heat Cycling etc.
A Tire 5 years old is unsafe for high speed running regardless of the amount of tread left, you may get away with it, but that doesn't mean it's safe. Personally, I change my Tires every 4 years (they usually need it anyway, but I do it even if they don't).
Happy Motoring!...Jim'99
