Old 03-02-2012, 12:51 PM   #15
onaFLYer
Originally Posted by jaykay View Post
Assuming all your vacum leaks have been addressed..
Do you think it is the larger Cayman MAF housing causing the code? Are you running a special tune or the standard 3.2 one
You could try adapting a smaller (3" dia) but similar Bosh MAF housing. I can find the PNs if you like. You may have to cut or it may press in!! I will be facing the same issues if I use the 987 box.....Have yet to find one
Nice car by the way!
I sure hope it has nothing to do with the housing, the whole point was to make it breath a little more. I haven't tried the 987 MAF yet, maybe I should. It is a stock tune, I plan to change to different TB later, and possibly IPD plenum then I will have it tuned to match.
This morning the light went out by itself, first time it did that. But then it came on again at lunch. Damn.
Any experience with Durametric?
just passed 525 miles today.
onaFLYer is offline   Reply With Quote
