Thread: Litronic Issues
Old 03-02-2012, 11:05 AM   #2
baldi
Originally Posted by Paul View Post
Have you checked the grounds for the lights?
I hadn't, but I just did and they're still grounded and secure.
I also went to take a look at the pins, and I think I may have found the issue. I noticed from both headlights I'm missing a pin (pics attached) Is that normal? That might explain why both headlights are out. If anyone has a diagram for what those pins are for, that would be awesome too (yes I'll search after I post this)
I also saw on the connector itself, I seem to be missing a metal receiving piece (pic also attached) Does anyone know how to remove the connector? I would like to inspect it further, but I'm afraid I might break the yellow clip holding it. I might remove the headlight tray to try to get to it, but if there's a secret to it (twist 10 degrees, push twice, pull once, tap your head, drink a beer, and tada!) then that would obviously be easier.
baldi is offline   Reply With Quote
