Thread: Litronic Issues
Old 02-29-2012, 06:57 PM   #1
baldi
Litronic Issues
I've been having an issue with my passenger litronic being intermittent, with no pattern on when it goes on or off. So after searching, I tried a couple things.
First, I swapped the bulbs. - No effect.
While doing so I noticed all the lights - side markers, fogs etc. flickered in unison. After searching I thought it might have been the headlight switch.
Second step was swapping the headlight switch. - This resulted in the driver side beam to flicker more than before, until I turned on the fogs. Once the fogs went on, the flickering stopped. Fogs off, flicker returns. The passenger side still didn't turn on. At this point I realized I havnt swapped ballasts to test them.
So third step was swapping the ballasts. - Now both lights dont turn on. Highs, fogs, daytime all work. It's only the litronics that don't turn on. Thinking it might be a loose connection, I made sure the ballasts were in tight, and the headlights went in correctly.
Now..I don't know what else to do or what else it could be. Does anyone have any ideas?
baldi is offline   Reply With Quote
