Old 02-28-2012, 11:59 AM   #20
ProjectM96
I am at 86,000 miles in my 2000 2.7 and the only things I have replaced are Water Pump and Rear plastic window and 1 inner tie rod and a few light bulbs. Starter is starting to go bad, but still has at least 1 year left in it. My rough idle was fixed by cleaning the throttle body.
Thats it, as far as I know from previous maintenance records, everything else is original except brake pads, tires, and air filter.
I expect your Boxster to last a while without any major problems since you just fixed the problem areas. IMS does not happen to every engine. Get the "IMS Guardian" to be safe.
ProjectM96 is offline   Reply With Quote
