Oh man... MEGUIARS PLASTX. $10 a btl or something. Came crystal clear and soft as NEW.
I've used a "soft" foam polishing pad on a rotary and ran this at 2k RPM for a good 5 min. Wiped out, cleaned, and just couldn't believe it.
The real blast was after I've done the same routine, but from the inside of the car i.e 2k spins for 3-5 min (prep for back aches my man!). Its only then that I've noticed that this product was simply meant for the Boxster rear foggy window (you do get lucky with silly produccts sometimes!). The windows came up literally brand new and all the small scratches vanished.
Note that my window's temp came up pretty hot after a few minutes of buffing at 2k (summer day). Not sure if this was a major factor to success but anyway, I'm convinced it did. I've left the roof down overnight for the window to relax while temp cooling down and all the stretch came back normal the next morning.
From only two meter away, you wouldn't make the difference between my window and a new one.
Luck with yours there
