Old 02-24-2012, 07:23 PM   #2
ed.w
'00 Boxster S Carbon Grey
ed.w's Avatar
Originally Posted by harryrcb View Post
If you smell oil, then you are leaking it somewhere and burning it. could be so many different things some were already mentioned. I also have seen AOS tubes including the tubes from the heads to the AOS leak. on an older car they dry out and crack. Power steering pump reservoir could leak and the oil stays on top of engine until you drive and some spills and burns on the exhaust. Had a car that did that.
It's like smoke, you see it you smell it , there is a fire.
Hi Harry. Could u tell me where is those AOS tube ? Thanks.
ed.w is offline   Reply With Quote
