Old 02-23-2012, 02:47 PM   #2
Johnny Danger
Johnny Danger's Avatar
Originally Posted by stephen wilson View Post
Sorry Johnny, I meant I was confused by Spyder's comments, I know the 986/987 wheels interchange, it's done all the time (and that the O/S has to be correct).
The 987 sizes work fine, it's been done. They will be a touch taller, but not enough to cause a problem. Some may argue they fill out the wheel well a bit better.
As you probably know, it's the difference in tire size that changes the overall circumference between the two. Also, keep in mind that the oem wheels used on the 987 platform vehicles typically have a much higher offset than the 986 . And, depending on one's suspension set-up, this can pose inner clearance problems . Thus, necessitating the need for spacers .
