Old 02-23-2012, 02:16 PM   #13
Johnny Danger
Johnny Danger's Avatar
Originally Posted by stephen wilson View Post
OK, you have me confused. You recently posted in another thread that 18x11 wheels fit on a 986???
The sizes I mentioned may not be OEM fitment to a 986, but by that logic you shouldn't use wheels from a 987 either.
As long as the wheels are hub centric (i.e. 71.6 center bore - which 986/987 wheels both are), then they're perfectly interchangeable . However, one has to carefully calculate how the difference in width and offset will effect the overall fitment between the two .
In the past, I've gone on record several times indicating that 10 inch wheel is about the widest that will properly fit on a 986 boxster .
