Old 02-11-2012, 04:42 PM   #12
Jittsl
SPB racer
Originally Posted by Brad Roberts View Post
The issue is: you are already at high RPM (little to no oil in the pan area) and now add in the banking... The engines (just like any engine with a regular oil pan) it puts all the oil into the heads. Getting the oil back into the pan (and/or limiting it to the heads) is a BIG )
I wonder if the difference has nothing to do with banked or not banked but rather the amount of time spent in a corner. A banked turn is really just an extremely long sweeper. And maybe what you are seeing is that the longer the car stays with forces pushing the oil away from centre the less oil you end up with in the sump. Just a thought. When I grenaded my 996 it was on the exit from the esses onto the back straight at WGI - a long, high G corner.
Jittsl is offline   Reply With Quote
