Old 02-09-2012, 12:30 PM   #1
442nd986s
Cigarette Lighter
Most european cigarette jacks are slightly bigger than (China) manufactured 12v power adapters.
So in order to make a standard 12v power adapter to work in euro cars, the adapter manufactures include a small plastic sleeve/ring that is placed over the 12v adapter tip. This ring has a few cut out slots to allow the metal contacts to still make the necessary contacts in the cars socket.
Think of the sleeve/ring as a shim: 1mm bigger than the diameter of the adapter by 1" long. If you need to see an example, go by a Radio Shack or Best Buy to view there power adapters.
Keep in mind this only pertains to cigarette jacks, NOT TO 12V DC POWER POINTS
442nd986s is offline   Reply With Quote
