As strange as it seems wheel width and offset will not effect alignment. But, different wheel specs respond differently to various changes to alignment so if you are competing with the car you might want to experiment with different settings.
Example, 18" wheels and tires may be able to get acceptable cornering with less camber since the slip angle of the tire is less.
