Old 02-08-2012, 12:43 PM   #2
thstone
Originally Posted by Burg Boxster View Post
you can check the relay but likely the compressor isn't kicking on b/c of low/no freon. See a qualified a/c specialist who will test it by putting in a dye (w/ new freon) and use a blacklight to find the leak(s).
+1 Most likely you were low on refrigerent when you stored the car and lost enough while in storage so the compressor won't switch on now. A local shop can check for leaks and re-fill and you'll be back on the road in no time.
