prodriver,
it seems like a pretty comprehensive build-up. one of the things that i like about jake's builds is that they address all of the "modes of failure." also having 300+hp ain't bad either.
while i don't need a motor right now, it's always good to have resources. buying a motormeister just doesn't cut it. i may give you a call if/when the time comes.
i think i read somewhere else that you've done 2 of the m96 raby builds. did you ever get the other motor on the dyno to see what kind of power it makes? while i'm leary of instant-g's work, it's hard to argue with his logic that the boxster motor makes significantly less hp/lt than the 996. something is choking it down. i am hoping to unlock the missing hp whenever the rebuild time comes. i am curious if your experience shows that the 3.6 makes 300+ as jake advertises.
brad
