Old 02-03-2012, 08:49 AM   #13
BYprodriver
BYprodriver's Avatar
Originally Posted by sgt brad View Post
Pro river, did you do all of the upgrades to chain tensioners,etc? Would you mind listing all of the build specs. 14k. Seems like a good price for someone lookig to upgrade and address all of the failure modes
Sgt, every part of the engine is cleaned & inspected for wear from the case to the bearings & bolts. Anything that can be upgraded is replaced with the best part available. New cam chains, IMS chain tensioner with the external preload spring, LN billet oil pump driveshaft, LN triplerow ceramic IMS bearing upgrade, New IMS chain tensioner paddle, New Cam tensioner wear pads, ARP rod bolts. Lifters & chain tensioners cleaned & tested in new oil heated to 275degrees.All recipricating parts dynamicaly balanced to half gram tolerance. Engine fully prelubed for initial startup including filling oil filter housing & pump & camshafts. Let me know if there are other build specs you are looking for.
