Old 01-30-2012, 01:04 PM   #2
thstone
Originally Posted by healthservices View Post
When you start having air mix issues (hot, warm, cold) then you can start worrying. The air mix door is covered with this and when the foam is mostly gone you will stop having 'cold' air from the vents when the a/c is on and super hot air when at full closed position.
Yes, this is a common problem with Boxsters as they age and will eventually affect most of our cars. It is also common for the temp controller to stop working or work erratically.
