Old 01-30-2012, 10:37 AM   #1
healthservices
Registered Boxster abuser
healthservices's Avatar
When you start having air mix issues (hot, warm, cold) then you can start worrying. The air mix door is covered with this and when the foam is mostly gone you will stop having 'cold' air from the vents when the a/c is on and super hot air when at full closed position.
