Old 01-29-2012, 09:03 AM   #6
madmods
Originally Posted by vitaminC View Post
Has anyone installed the pipes available from delubozparts ( http://986forum.com/forums/273505-post1.html)?
I am following the basic outline described by Maxspeed, and it seems like the small section of pipe that goes between the test-pipe and the muffler's u-pipe is way too loose. Only one clamp per side is shipped with these pipes, and it doesn't seem like the original double-clamp will slide over the pipes.
Any thoughts?
This is going onto an '03 S with an otherwise stock system.
Had a few 'puff' here and there issues with my aftermarket exhaust system and used "header wrap" on the U joints. Like DFW02S said, just re-use the stock clamps and you should be 'sort of okay'. That's what I did but still had a few puffs coming out... didn't want to clamp this too hard fearing to bend the pipes so I've finished it all up with header wraps. That did the trick right away (flex and stuff).
Use link ref only (I don't know this seller nor have purchase from there)
DEI 010110 Exhaust Header Heat Wrap Complete Kit Black (607078101105) | eBay
madmods is offline   Reply With Quote
