Originally Posted by madmods
Hey guys, first who does this Boxster belongs too? if anyone knows
RW5 Porsche Rim - Roderick Wheels
I am talking to these guys about getting a rear rim done in the 19X9.5" or 19X10". Unfortunately they only come in 19X11" and that's it. However, these same guys, obviously wheels "Pros", and they assure me that the 19X11" will slide on the 986 without any modifications at all. For info.... the rear tyre on this advertised Boxster is a 295/25/19 (factory Porsche 996).
If this all true, and can be confirmed, I think I will be shooting these guys my CC number and graba set in silver.
So how can we remotely confirm this 19X11" is a "Go" for the little roadster?
Hi,
the RW5 rim in 19x11 offset 40 fits with a 8mm spacer, but i donīt think, that`s possible with a 295 tyre... however... in this configuration only a 265 or 275 should possible, because the 295 would be scratch outside on fender and perhaps inside on the strut. If you want to get lowering your boxster, keep in mind that each rear fender must be widened for 1" and needs a more negative camber!
