Old 01-25-2012, 05:01 PM   #3
Johnny Danger
Johnny Danger's Avatar
Originally Posted by Steve Tinker View Post
I'm just about to install new headers and cat delete pipes (but retain the rear muffler) on my 2001 S.
Before I squeeze my old bones under the car, I need a couple of pointers from people who have already completed the installation.
I assume that I can remove the headers first and then pull out the cat section of the exhaust system without actually removing the standard muffler (at least I hope I can - I don't want to remove the muffler on my own if I can help it).
Looking under the car, will I have to remove the 2 x diagonal brace rails and aluminium plate below the gearbox to help with the removal / installation of the pipes?
The plan is to a) remove the rails and plate, b) remove the headers - no O2 sensors in Oz, c) remove the cat pipes / O2 sensors after unbolting at the muffler.
I assume the installation (as they say) is in reverse order.
And can I reuse the header bolts - assuming they come out OK?
Any handy hints greatly accepted.
The oem exhaust is comprised of 3 basic segments : headers and precats, secondary cats and cat-back (muffler) . They can all be removed separate of one another . It sounds like your approach is fine .
