Old 01-23-2012, 05:47 PM   #2
Meir
1999 base
Meir's Avatar
It will be very difficult to locate the leek without removing some covers.
I head the same issue, and it was the water pump.
Leaking only at idle running good at high rpm.
Remove the front engine cover (behind the seats), the top cover and the under cover.
That will help you detect the exact location of the leak.
I hope for you that one of he hoses recently replaced was not tighten enough.
New water pump is a little bit pricy.
