Old 01-23-2012, 06:40 AM   #3
Bigsmoothlee
P0302 Misfire, Cylinder 2, Damaging to Catalytic Converter
Boxster Check Engine Light Codes
Its most likely just a regular cyl #2 misfire. When there is a misfire that damages the cat conv, it means it was bad enough that the DME shut the injector on that cyl down to save the cat.
I would just throw some new spark plugs in, and change the coil on cyl #2. That should take car of it for good
Bigsmoothlee is offline   Reply With Quote
