Old 01-22-2012, 06:39 PM   #11
Squozen
Squozen's Avatar
"Clutch Judder is caused by the clutch components and flywheel not meeting concentrically. The friction surfaces rub concentrically causing a low frequency vibration that is transmitted to the car via the engine/gearbox mountings and drive shafts."
But if the engine isn't running, that can't be the issue.
I'm only about 90% sure I feel it without the engine running, so I need to check again when I get home.
Squozen is offline   Reply With Quote
