Old 01-22-2012, 06:18 PM   #7
WhipE350
Autobahn Glanz
WhipE350's Avatar
Originally Posted by Squozen View Post
But with the engine off the flywheel isn't spinning, so you'd be eliminating roughness from a cracked or bent component...?
Maybe throwout bearing...but then you would feel it pushing in too. It sounds like your are describing a feeling coming from the actual clutch and not the pedal or master/slave cylinder.
If there is even a slight bit of air in the system that will make the clutch feel funny at the top on release or it may not even release all the way, doesn't sound like you are describing that.
Maybe Landrovered has it right, but I'm not familiar with that unless it means the clutch is worn out.
