Old 01-22-2012, 12:03 PM   #20
Ghostrider 310
Ex Esso kid
The cooling system and the oil tube should have zero nexus, two separate systems, go ahead and fill the cooling system. As for checking the leak, if a broken mount allowing the engine to torque or twist is what fractured the oil tube you might not see the event repeated. If you have already ordered the part, I would research it's replacement, look at the part itself when it arrives for clues as well. Then execute the repair, fill all fluids and check it, otherwise you might re-soil the area you just cleaned with a still leaking yet to be replaced tube, hope that helps good luck.
