Old 01-17-2012, 11:31 AM   #1
Aron in Toronto
If you search for hardtop install, the instructions should show where the rear window defrost wire outlet is located. The outlet is in all Boxsters and is under a small black plastic cover behind the driver's roll bar. It shouldn't be difficult to fabricate a small "jumper" wire to connect this outlet to your rear window defrost plug.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
