Old 01-15-2012, 05:00 PM   #10
WhipE350
Autobahn Glanz
WhipE350's Avatar
The oil filler tube has a joint right over the middle of the engine and already likes to sag if it gets a chance. A bad engine mount would probably be just enough to break the joint loose. You'll need to get that top up and look at the engine from the top. If it is what we all hope you'll probably be able to just clean it up and put a new clamp on. I just put a new filler tube in (the part from the filler side) and trust me it is not fun unless you have a good tool to hold the clamp...again you probably won't need a new one.
Keep us posted and good luck!!
