Thread: Rear Fog Lights
Old 01-11-2012, 07:37 AM   #29
Mark_T
I like your idea Eric, and I think Ekam's suggestion is an excellent way to tackle it.
Suggestion for frequently covered topics could be:
-top doesn't work (handbrake switch)
-psgr side fog light not working (of course)
-battery dead, frunk won't open (use cable)
-key won't turn in ignition (take pressure off steering wheel)
-coolant light flashing (low coolant or dead engine fan)
-winter storage (also covered in owner's manual)
-white smoke (failed AOS)
-puff of bue smoke at start-up (normal)
-list of failed ignition switch symptoms
-top replacement (link to Mike's tutorial cuz if you can't follow this you shouldn't be doing it)
-list of handy special tools and their uses
Hey, I have an idea - maybe someone should write a book of a hundred or so common Boxster projects....
'99 black 986
