Old 01-08-2012, 10:49 AM   #22
tonycarreon
tonycarreon's Avatar
Originally Posted by landrovered View Post
Can we get confirmation from Wayne that Pelican is actually planning to release an IMS bearing retrofit?
the product page is up Pelican Parts - Product Information: PEL-IMS-1
and the description ( Project 14: Intermediate Shaft Bearing Upgrade - Page 1 ) says:
Originally Posted by pelican's website
The Pelican Parts Intermediate Shaft Bearing Replacement Kit is a less-expensive solution to the excellent LN Engineering kit. The Pelican kit replaces the factory bearing with a very similarly manufactured bearing (and with an improved seal and updated center bolt). This one kit will work with either the single or dual row IMS on your M96 engine (1997-04) or your very early 2005 engine that doesn't utilize the newer oversize bearings. We recommend that the bearing be replaced each time a clutch replacement is performed (every 40,000 miles or so).
The Pelican Parts Intermediate Shaft Bearing Replacement Kit includes:
• Improved center bearing bolt
• Outer race spacer (for engine with double-row bearings)
• Inner race spacer (for engine with double-row bearings)
• Replacement intermediate shaft bearing
• Center bolt O-ring
• Center bolt nut
• Long center bolt spacer (for engine with single-row bearings)
• Short center bolt spacer (for engine with double-row bearings)
• Snap ring (for engine with single-row bearings)
• Spiroloc snap ring (for engine with double-row bearings)
• 3 new micro-encapsulated cover bolts
• 3 M6x25mm installation helper bolts
• 3 M6x1x25mm set screws
• Updated 3-groove flange seal
• O-ring for older style flange seal
The Pelican kit also uses the stock intermediate shaft bearing cover as a way to reduce the total cost of the kit.
