Old 12-31-2011, 03:41 PM   #10
MileHighBoxster
Matt
MileHighBoxster's Avatar
Actually I believe the problem started when he put hankook tires on his car & nothing else was changed. If that is correct I can troubleshoot his car via this forum.
Hmmm. You posted the above on 12/19 - what's the problem?
My suggestion would normally be, if your entire problem started with a simple tire install, to go back to the place that did the initial work and have them replace your tires and balance your car. If they created the problem, they should fix it. If it was perfect prior to the install, the install is the problem. However, I see from your first post, weeks ago, that you bought the tires and then had them installed by someone else. I would always buy the tires locally, and have them installed in the same shop so that if there was a problem, they could take care of it for you.
MileHighBoxster is offline   Reply With Quote
