Old 12-31-2011, 03:13 PM   #11
MileHighBoxster
Matt
MileHighBoxster's Avatar
Actually I believe the problem started when he put hankook tires on his car & nothing else was changed. If that is correct I can troubleshoot his car via this forum.
Well then put your expertise where his problem is. If you can troubleshoot his problem, don't spew it, do it. What are you waiting for, he's been waiting for weeks on you? When you open the door, it's time to put up or....... He's had it balanced several times, and he's changed his tires at least 4 times with no result. I see from your previous posts on this thread, you have NOT solved his problem.
MileHighBoxster is offline   Reply With Quote
