Old 12-29-2011, 11:53 AM   #3
Bala
Originally Posted by Brad Roberts View Post
The guy above me is correct If it is nearly impossible to take the cap off with the engine running, the AOS is bad. It should have a slight suction on it with the engine running.
I would not be too concerned about oil in that tube (unless you dumped a quart out of it) :LOL:
B
Definitely not a quart. At $7 a quart that would be unaffordable! I will check the oil cap today. Working on the plug tubes and coil tubes.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
