Old 12-20-2011, 08:39 PM   #1
Meir
1999 base
Meir's Avatar
You did not preform the most important test
Under DME, check for camshaft deviation.
The reading will show you a value between 0 and -8.
The most important thing is to see that the value stay steady on idle. The graph will show a strait line.
That will confirm that the IMS is in a good shape. If the line go up and down, well... you have a problem.
Good luck
