Old 12-16-2011, 02:10 PM   #2
Bala
If you lay the glass cloth over the foam and epoxy or resin it. It will stick to the foam. You need to entirely cover the foam mold with release fabric so it'll release after it cures. For something like this it's best to vacuum bag it. Too bad you are far away or I could help you out. But again it's cold here so the resin has jelled. Look around for boat builders as there are some in Finland and they might be able to help you out. Check f-boat forum in yahoo.
