Old 12-12-2011, 09:52 AM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by jacabean View Post
i was under my car today bleeding my clutch . i noticed i have a torn outer cv boot do you guys think this is the cause of rear end vibration at 80 mph and up ? what's the best coarse to take to fix. i was looking in the 101 book and this is not looking like a fun job !
You must remove the axle & boot, then clean the CV joint & inspect for wear then replace or repack with grease. If the CV joint is worn it should make noise on hard turns.
