Old 12-03-2011, 06:09 PM   #1
Ghostrider 310
Ex Esso kid
Originally Posted by pothole View Post
Planning on removing the AC, too. Never use it. Rarely hot enough in the UK to need it. Even when it is, it's a nice change to be too hot for once!
That is going to require a special belt for sure then, at NAPA you can get gates belts in small increments larger or smaller. With just the under pulley a belt change was needed. As long as you have it out, pop off the tensioner and rollers, the bearings inside come out easy and can be bought inexpensively and replaced.
