Old 12-02-2011, 02:05 PM   #2
milliemax
First of all, Thank You All for helping me. Burg, You get the donuts !!! The problem was the bulb (Halogen) (original) I changed the bad driver's side and then the passenger side also. And may I add, I found a small bare cable with a loop on the passenger side light area. It was tucked along the left side of the wall between the trunk and where the headlight pod (small watermelon) slides into. I pulled it out to find that it is the EMERGENCY HOOD RELEASE CABLE. Looking around and wondering how someone would find it ? NO WAY unless you pulled the front bumper. So I re-routed the cable towards the hole where the small bumper plug is for the tow ring. I tied a small fishing line (50 lb test) to the cable and left the fishing line tucked into the small hole and replaced the bumper cap. Now !!! I can "POP'' the front trunk in an emergency, and QUICK !!!! Dead battery is no longer a worry. And John99boxter, Do not need the loan this time, thanks a million !!! Max
milliemax is offline   Reply With Quote
