Old 12-02-2011, 11:13 AM   #10
jaykay
jaykay's Avatar
Thread is 14mm X 1.5 & Boxster sending unit is on pass side & there is alot more room there than driver side. I put the aftermarket sending unit on my drivers side (temporally) so as not to interfere with oem warning light.
Thanks that is great info. This may mean I will loose the idot light if I put temp and pressure transducers in the left and right cam covers.
It would be nice to test the output of the 996 sender and match it to a gauge that works with the look of the car.
Did you actually get a temp sensor with an adapter to fit on the passenger side?
Witch gauge sensor combo did you use?
986 00S
