Old 11-27-2011, 04:01 AM   #10
smshirk
Originally Posted by DenverSteve View Post
Johnny,
I am looking at a set of tires/wheels for winter wear that are 19" and the rear tires are currently 295/30's. The tire calculator shows them to be comparable to my stock 255/40/17's. The offset would go from 55 to 67. You seem to have much more tire/wheel knowledge than I. Do you think these will fit okay?
S.
The tire calculator showed that my 18 x 11 with 295 30s would fit on my 986S. It wasn't even close. If I used a wide enough spacer to get far enough away from the shock tower, the tires stuck way past the fender, plus the 295 30 diameter looked weird on the stock ride height. I've had this brand new set of Gemballa wheels and tires sitting in the basement for 3 years since selling my 996 and finally tried them yesterday.
I have a set of 18" CCW race wheels Complete Custom Wheel - Wheel Profiles in Boxster offsets that are very light but won't accept center caps. I've been trying to figure out a way to attach some caps without screwing the wheels up. They have holes drilled all around the center and the outside to reduce weight, so I'm thinking it wouldn't hurt to drill and tap a set of center caps in the middle. Does anyone have an opinion?
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
