Old 11-21-2011, 07:23 PM   #20
Jaxonalden
Jaxonalden's Avatar
Originally Posted by onaFLYer View Post
When the 550 model came out, it had a jump in power over the standard S model. I was told that the airbox is different, this is second hand info so,....
Fly, you are absolutely CORRECT! The 2004 anniversary 550 and the 987's utilize the same basic design concept as the EVO intake. The airbox is built as an all encompassing unit, not like the EVO that utilizes panels to seal the air filter from the engine compartment.
Below; 550/987 airbox assembly breakdown ($560+ tubing from airbox)
Porsche Boxster Air Cleaner Parts
550/987 air filter
Pelican Parts - Product Information: 987-110-133-00-M67
EVO intake ($379)
Pelican Parts - Product Information: EVO-INTK986HF
The filter is an oval, tube shape like the EVO, but a lot bigger to allow more unrestricted air flow. It's design is a straight shot from the left hand intake port, through a big snorkel (to probably suppress sound), to the filter and to the MAF. The 550/987 intake set-up is an OEM answer to the EVO intake. Porsche engineering at an EVO price, and you can to install it on your car.
