Old 11-06-2011, 11:04 AM   #8
Lance White
As a mechanic who does a lot of suspension work for a living, find out for sure what is wrong with your car instead of throwing parts at it. If you don't have a lift at least get it on 4 jackstands and start looking for the slack in joints and condition of rubber boots, and also spin the wheels to find bearing/rotational issues. Almost any issue (tie rod, ball joint, warped rim, bad tires, bad wheel bearings) can be visually/audibly diagnosed and pinpointed to the exact component. You have to pull around a little bit to find things, but worn ball joints and tie rods will reward you with an audible clunk and you can see the lost motion.
Lance White is offline   Reply With Quote
