Old 10-25-2011, 06:19 AM   #2
MN 986
MN 986's Avatar
It really isn't that bad, although I was a little concerned since I had just picked up a pair of Litronics and I hadn't even put them on the car yet. Just search 'amberectomy' on the web/forum and you will get good instuctions with pictures. I picked up a small cheap soldering iron and put some foil around the hole to help insulate the heat a little, but you do have to be careful.
The results are well worth it in my opinion. Good luck if you decide to do it!
MN 986 is online now   Reply With Quote
