Old 10-21-2011, 07:03 PM   #1
blackgrape
Smile Xenon Headlight Not Moving, Set Too Low
I have a 2004 Boxster S.
My car just failed an inspection due to the beam on one side being set too low. Upon examination, I notice the left headlight is not moving on start-up. The right-side headlight moves, adjusts to correct level and appears to be working fine.
I can hear the servo motor whirring on the left side, it's just that the light doesn't move. It appears to be jammed in a low position.
Any ideas?
If this is expensive to correct, is it possible to disable the movement function and leave the headlight set manually? I live in a country where auto-adjust headlights aren't mandatory.
I'm not very technical, so if I need to take it to a dealer, I don't want him selling me the most expensive solution. So any information you can arm me with would be greatly appreciated.
blackgrape is offline   Reply With Quote
