Old 10-21-2011, 06:11 PM   #2
J Tinsby
J Tinsby's Avatar
If they can do it
Originally Posted by nprboxster View Post
tried AM and almost nonexistent reception. from none to barely make out. i'll bring back in and see what they can do, luv the deck otherwise. nice to hook ipod up, or put usb stick in full of music and love the built in bluetooth, just need to fix issue withreception n good to go.
ps, is it expensive to have rear speakers put in thebox behind seats? what happens when you remove box when you open engine compartment if now has wired speakers?
I am not surprised by your findings, they are as I predicted previously. Poor FM and lousy AM if any.
If the installer has another radio like yours, maybe they can hook it up on the bench with an antenna to see how it works in that setting. If AM and FM are good then it's one of two things.. your antenna is somehow damaged or your radio is faulty. Doing a bench test will save the hassle of installing another rig only to find it doesn't work either.
Good luck!
J T
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
